HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Drivetrain
Transmission
Fluid
SPONSORED LINKS
1993 Ford F-150
WHITEGOLD911
MEMBER
1993 FORD F-150
Engine Mechanical problem
1993 Ford F150 V8 Two Wheel Drive Manual
put transmission fluid in oil by mistake. Will it hurt engine?
Sunday, May 25th, 2008 AT 6:52 PM
MECHANIC
Hi there,
Yes, this will not be good in your engine, change the oil & filter before you drive anywhere.
Mark (mhpautos)
SPONSORED LINKS
Sunday, May 25th, 2008 AT 8:00 PM
BLACKOP555
MECHANIC
Not good, not good at all, you will need to change the fluid and filter before you run it AT ALL.
How long did you run it and how much did you put in it?
Sunday, May 25th, 2008 AT 8:15 PM
Please
login
or
register
to post a reply.
Related Transmission Fluid Content
1982 Ford F150 No Trans Fluid Flow
Transmission Problem 1982 Ford F150 V8 Four Wheel Drive Automatic 389tho Miles Gday I Have Just Had A C6 Trans Overhauled And Fitted...
Asked by
atheistjim
1982
FORD F-150
Transmission Rebuild Fluid Capacity
I Have Recently Replaced All Friction And Steel Plates In The 4r70w And Have New Torque Converter I Will Be Adding. Can You Tell Me What...
Asked by
starcity
1 ANSWER
1999
FORD F-150
97 Ford Taurus 163000 Miles
Yesterday, While Driving Home About 60-65 Miles Per Hour, My Engine (rpm) Suddenly Revved Up To Almost 4000. When I Let Up On The Gas, It...
Asked by
jessica78233
FORD F-150
W R O N G Fluid!!
1991 Ford F-150 Pickup W/351; Efi; Auto; 2 W/drive I Stupidly Poured About 1/2 Quart Of Automatic Transmission Fluid Where I Was Supposed...
Asked by
PMRritter
1 ANSWER
FORD F-150
1995 Ford F150 Transmission Trouble???
I Have A 1995 Ford F150 4x4 With A 302 V8, Automatic Transmission, Push Button 4x4 144, 000 Miles. I Had A Looad Of Coal On It, Was...
Asked by
zero198209
1995
FORD F-150
VIEW MORE
SPONSORED LINKS
Automatic Transmission Service
Transmission Service 65RFE RAM 1500 2013-2022
Transmission Filter and Fluid Replacement
Online car repair manuals
