2006 Ford F150 starting
2006 FORD F-150
70,000 MILES • V8 • 2WD • AUTOMATIC
BROWNE
The lights are bright, and jumper cables were connected, but when the switch is turned to start, the lights don't dim and nothing happens. I am thinking that this is a bad starter relay. Is it on the firewall?
Oct 7, 2008 at 7:51 AM
BMRFIXIT
  • 19,053 POSTS
If you have any thing on the firewall by the battery its a starter solenoid
and I would check it 1st then check the starter mounted at the rear low of engine by the tranny
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 7, 2008 at 11:19 PM
