2006 Ford F150 Rotors
2006 FORD F-150
35,000 MILES • V8 • 2WD • AUTOMATIC
PROBY81
First question: On the F150 2 wheel drive do you have to replace any barrings? If so how do you do that?
Second question: Do you need to replace your break pads when replace your rotors?
Mar 20, 2009 at 4:37 AM
JAMES W.
  • 2,394 POSTS
On a truck as new as yours you needn't wory about any bearings. As far as the brake pads, it' foolish not to replace the pads if your putting on new rotors. USED rotors, I would probably use the old pads if they weren't worn too much.
Apr 1, 2009 at 6:40 PM
