2006 Ford F150 Rear of truck shakes when reaching speeds of
2006 FORD F-150
79,000 MILES • V8 • 2WD • AUTOMATIC
MSB1960
I recently had 4 tires put on my truck. Now when I reach speeds around 50 or 55, the bed of the truck starts to shake, I can even feel it in the cab of the truck. I took the truck back...they pulled all tires off and re-balanced...even moved them around. It still does it??? It didn't do this before I bought the tires.
Any suggestions???
Thanks
Sep 8, 2010 at 5:37 AM
  • 110,194 POSTS
Either the tire balancer is bad, they bent a rim when changing the tires, or you have a bad tire. Check for any evidence of wheel damage or shifted belts.
Sep 8, 2010 at 7:01 AM
