2006 Ford F150 REAR OBJECT SENSOR MALFUNCTION
2006 FORD F-150
60,000 MILES • V8 • 4WD • AUTOMATIC
CRITTERDOC1
The button on the lower dash that turns on/off the rear bumber object sensors is "stuck" or lit in the off selection. Pressing the button multiple times will not cure the problem. Cleaned lenses on the bumper sensors, no help. All wires seem to be connected as needed as best I can see. Oddly, some days, when the temperature outside is a little warmer, it works. This problem first began when we had our first real cold snap this winter. Do I have a bad sensor(s), switch, or both? How do I find out?
Jan 29, 2010 at 2:46 PM
MERLIN2021
  • 17,250 POSTS
Doc here's the scoop, Tailgate must be closed, ignition in run position, reverse gear selected, Reverse lights come on?, I will send a PDF file via email, but you may need to have the truck scanned for "B" and "C" codes, generic scan tools dont read these, so a local garage or Ford can scan it, the PDF has all codes and testing for them included.
Jan 31, 2010 at 12:02 AM
CRITTERDOC1
Thanks a bunch, hoping it was something simple, I can find the dip stick but that's about all....lol to the shop we go, will take your PDF file just in case
Jan 31, 2010 at 12:48 PM
MERLIN2021
  • 17,250 POSTS
OK Let me know what happens.
Feb 1, 2010 at 9:48 AM
