rear differential service and fluid type?
KERMIT25
How often does the rear differential fluid need to be changed?
Jul 10, 2008 at 6:29 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. The service manual shows that the rear differential oil is recommended to be changed at 150,000 miles. Here is a tutorial showing how to change differential gear oil:
https://www.2carpros.com/articles/differential-service
I've attached picture steps below on how to change the differential gear oil including the recommended type. Hope this helps an thanks for using 2CarPros.
May 17, 2021 at 6:20 AM
