2006 Ford F150 overdrive
85,000 MILES • V8 • 4WD • AUTOMATIC
COBOY33
Between 40 and 55 mph the overdrive wants to kick in and out what causes this.You can turn the overdrive off untill ypu reach 60 and it dosn't do this.I have allready had the transmission serviced.
Apr 18, 2008 at 9:04 PM
JOE6770
  • 12 POSTS
it may not be your overdrive.it can be your plugs and cop boots.change your plugs and check the boots.if the boots have a crack it will cause a miss fire and that is what you are feeling.
Apr 19, 2008 at 3:52 AM
