2006 Ford F150 Missing/hesitation
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOUDELAR
I have changed fuel filter yesterday, I can feel the diff. in power, but still misses/hesitates when going up incline. Air cleaner is new. Could it be bad plugs/wires?
Jun 10, 2010 at 3:32 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 10, 2010 at 4:32 PM
