2006 Ford F150 hesitates when going up hills
90,000 MILES • V8 • 4WD • AUTOMATIC
SALTWATER
truck runs fine except when i go up hill my truck hesitates and jumps until i give it gas then itgo back to running fine
Mar 1, 2010 at 1:47 AM
  • 75,988 POSTS
Hesitation,chugging,bogging,lack of acceleration,etc.
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 1, 2010 at 10:27 AM
