I replaced my fuel pump, now the truck will not start
Mar 14, 2010 at 1:03 PM
✓Experienced Mechanic
Do you hear the fuel pump come On when you turn key On? If so check the fuel pressure if its within specs though its new. If not inspect and test the fuel pump fuse, fuel pump relay and inertia fuel cut off switch
