2006 Ford F150 Engine runs rough
2006 FORD F-150
84,000 MILES • V8 • 4WD • AUTOMATIC
DAVID84
When in drive and in motion (accelerating or coasting) my engine is running rough, when I brake the RPMs drop to about 600 and the roughness is even more apparent. It runs completely smooth in reverse or when idling (completely stopped in drive or in park. Any ideas as to what may be causing this?
Feb 17, 2010 at 7:41 AM
Hi david84, Welcome to 2carpros and TY for the donation
Inspect and test all the following listed below:
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor
Feb 17, 2010 at 9:55 AM
