2006 Ford F150 Engine missing/sputters
67,000 MILES • V8 • 4WD • AUTOMATIC
DENNIS BUCK
I have a 2006 Ford F150 with a 5.4 liter v8 It has started missing and sputtering when running at lower RPMs. I changed the inline fuel filter and checked the air filter. I have checked the spark plugs and wires. what else could it be. The engine warning light has flashed a few timies but never came on and stayed on
Feb 27, 2008 at 2:14 AM
MERLIN2021
  • 17,250 POSTS
Get the codes read, autozone will do it free, post codes here when you get em...if it flashed it's in memory!
Feb 27, 2008 at 4:09 AM
JOE6770
  • 12 POSTS
the boots on the cop's could be bad.change the boots and plugs.plugs should be changed every 60000 miles.if there is a split in the boots it can ark and send a miss fire.
Mar 22, 2008 at 3:34 AM
MERLIN2021
  • 17,250 POSTS
The boots could be a misfire problem, but it would occur at all speeds...
Mar 22, 2008 at 4:58 AM
