2006 Ford F150
2006 FORD F-150
DALECASAS
How do I remove the rear rotors
Jun 30, 2010 at 11:46 AM
  • 110,211 POSTS
The process is based on the size of the rotor. Here are directions I found for all of them.
2.Remove the rear disc brake caliper.
NOTE
If the rear brake disc binds on the rear parking brake shoe and linings, remove the adjustment hole access plug and contract the parking brake shoe and lining.
3.Remove the rear brake disc.
4.Measure the rear brake disc, and resurface if the disc surface has been scored. Install a new rear brake disc if below minimum thickness specification.
5.Installation is the reverse of removal.
1.Before servicing the vehicle, refer to the Precautions Section.
2.Remove the rear wheel and tire assembly.
3.Remove the caliper.
4.Remove the disc brake pads.
5.Remove the brake disc.
6.To install, reverse the removal procedure.
CAUTION
Make sure to apply a thin coat of anti-seize lubricant to the hub flange only. Do not allow the lubricant to make contact with the wheel studs, brake pads or brake disc.
7.Apply a thin coat of anti-seize lubricant to the wheel hub flange.
Ford Full-Floating Axle
See the procedure under Rear Axle Bearings.
w/Dual Rear Wheels & Dana Axle
with Ford 10.5 Inch Axle & Single Rear Wheel
2.Remove the anchor plate.
3.Match-mark the brake disc and one stud.
4.Remove the brake disc.
Apr 6, 2021 at 5:11 AM
