1995 Ford F-150 rotor removal
RICK53
  • 1995 FORD F-150
  • V8
  • 4WD
  • 150,000 MILES
How do you rmove the front rotor of a 1995 F150 4wd?
Thursday, April 2nd, 2009 AT 4:57 PM
JAMES W.
  • 2,394 POSTS
Remove front tire.
Remove "tinnerman clips from lug nuts.
Unbolt caliper from caliper bracket and secure.
Remove caliper bracket from hub.
Give the rotor a "rap" with a hammer being careful not to hit the lugnuts.
Rotor should slide off hub.
NOTE; The caliper bracket bolts are glued in with "thread locker" and are tight.
Installation is the reverse except, you will need to re-compress the caliper piston with a large "C" clamp to accept the new pads.
Thursday, April 2nd, 2009 AT 5:58 PM
RICK53
Thanks for the info however, you must have not paid attention to the 4WD portion of the question.
Sunday, April 12th, 2009 AT 2:29 PM
JAMES W.
  • 2,394 POSTS
Sorry about that. I went back and checked your post and I DID miss that.
Sunday, April 12th, 2009 AT 4:31 PM
