2006 Ford F-150 Engine shaking a little
2006 FORD F-150
58,000 MILES • V8 • 2WD • AUTOMATIC
FORDTRUCK2006
  • 9 POSTS
My truck is starting to shakes a little , but only when I'm in park or idling. It does well while I'm driving on the road. Thanks,
Jesse S.
Nov 8, 2010 at 1:50 AM
  • 110,240 POSTS
Have you checked for vacuum leaks? When was the last tune up?
Nov 8, 2010 at 11:18 PM
FORDTRUCK2006
  • 9 POSTS
I have never done a tune-up. Only the basics like the oil changes and replacing the oil and air filter. I have yet to replace the spark plugs and wires.
Nov 8, 2010 at 11:25 PM
FORDTRUCK2006
  • 9 POSTS
[quote="Jacobandnickolas"]Have you checked for vacuum leaks? When was the last tune up?
Nov 9, 2010 at 12:04 AM
  • 110,240 POSTS
Actually, the mileage is low for the vehicle and a tune up, but I think it may be a good idea as well as checking for vacuum leaks.
Nov 9, 2010 at 2:45 AM
FORDTRUCK2006
  • 9 POSTS
How about the fuel filter? Could that be the source of the problem and perhaps adding some sort of additive to clean the fuel injectors?
Nov 9, 2010 at 2:52 AM
  • 110,240 POSTS
It could be part of the problem. You may want to check fuel pump pressure to see if it is low. Here is a how to:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Nov 9, 2010 at 5:28 AM
