2005 Ford F150 Trouble Starting
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVID 6363
This problem happened about a month ago, yesterday and this morning. As I turn the key to start the pickup the starter turned over for just a second then stopped. The power to everything is cust for a second because the radio and clock has to be reset. Whe I turn the key the second time the pickup starts up. I'm in south Texas so the temperature is humid and atou 50 degrees when this happens.
Feb 23, 2010 at 2:33 AM
  • 110,246 POSTS
Chances are you have a bad connection at the battery. What I recommend is removing the battery terminals and cleaning them and make sure they are tight when you replace them.
Feb 26, 2010 at 5:55 AM
