When driving at normal speed it feels like the the tranny is constantly skipping (not slipping) from drive to overdrive or trying to jump out of gear, but appears to do it mostly after warmed up. If i turn the overdrive off it still feels the same. At hiway speed with overdrive off it feels alot better. With overdrive on it still has the the same problem. Also have a problem with the passing gear. When passing gear is in i can only go about 50 mph and then while still in passing gear (with out shifting) vehicle will suddingly gain speed and go to about 65mph
Sep 5, 2010 at 5:23 AM
