2005 Ford F150 ROTORS AND BRAKES
61,000 MILES • V8 • 2WD • AUTOMATIC
FORDF15038
I went in for my 60000 mile maint. And was told I need new brakes and rotors on all four wheels. Reading some of the forum notes on the net there seems to be a lot of negative posts on ford rotors (made in China out of cheap metal) and will warp easy won�t last more than 10-20K. The brake pads and rotors on their now are the original, so I did get 60K out of them. The bad thing is the rotors are worn down beyond turning and the pads have never been replaced. I just was asking how can the rotors wear out before the pads? And should I stick with OEM rotors and pads from the Ford dealer? Thanks
Eric
Jun 17, 2010 at 3:41 AM
  • 110,248 POSTS
Eric,
That is odd. I have a 99 with 100K on it and the rotors are fine. Were you getting a pulsation when you use the brakes? Do you know how to use a micrometer to measure the rotors' thickness?
Jun 18, 2010 at 5:47 AM
