2005 Ford F150 Rattle in transfer case
62,000 MILES • V8 • 4WD • AUTOMATIC
DMILLER1960
I am kind of embarrased to tell you this, but here goes. I was having problems with my 4wd trying to kick in while I was driving down the road in two wheel. I did some research and raplaced the vaccum shift solenoid. (Now comes the embarrasing part). I removed the solenoid and put the air compressor in both upper and lower lines to blow them out. When I blew out the lower line I heard a loud pop. Now after replacing the solenoid when I step on it I hear a rattling. When I engage the 4wd and eccelerate it does not rattle. Do you have any idea's?
Thanks Doug
Aug 19, 2008 at 11:23 AM
BLACKOP555
  • 10,386 POSTS
sounds like you damaged the transfer case you might want to make sure it is switching into 2wd fully.
basiclaly this is out of the scope of a home mechanic, your gonna have to take it in.
Aug 19, 2008 at 12:53 PM
