2005 Ford F150 Radio Failure
46,000 MILES • V8 • 2WD • AUTOMATIC
KWREN
My radio will cut off and on while driving. It may stay on for an hour or for 2 minute it is spuratic. When the radio cuts off and I push the on/off button it displays LOW BATTERY on the radio display.
I have checked the fuse, when the failure occurs the AMP meter does not move. I do not think the battery is bad becasue the lights do not dim and there are no other symptons of low battery. The temps here are in the teens on the mornings and it cranks fine when I start it in the mornings.
Jan 25, 2008 at 4:15 AM
COLOMBIAN
i AM KINDA HVIONGTHE SAME PROBLEM, MY TRUCK WAS TOWED NOW MY RADIO IS ALL MESSED UP AND SHOWING THE SAME THING LOW BATTERY, NONE OF MY FUSES ARE BAD AND THE DIAGNOSTIC IS FINE ? WE SHOULDD PUSH FOR RECALL! I HAVE THE SAME YEAR
Feb 8, 2008 at 11:47 AM
