2005 Ford F150 miss
CHARLES789
Engine Mechanical problem
2005 Ford F150 V8 Two Wheel Drive Automatic
have 2005 f-150 triton motor has miss on #3 cylinder new plugs &coil pack no help what else could it be valves or head gasket runs good at about 70mph
Nov 11, 2009 at 11:02 PM
  • 110,248 POSTS
Have you checked compression to that cylender? Also, are you getting power to the coil pack? Finally, if you have spark, have you checked the injector to see if it is pulsing?
Nov 19, 2009 at 1:36 AM
