2005 Ford F-150 miss
CHARLES789
  • 2005 FORD F-150
Engine Mechanical problem
2005 Ford F150 V8 Two Wheel Drive Automatic
have 2005 f-150 triton motor has miss on #3 cylinder new plugs &coil pack no help what else could it be valves or head gasket runs good at about 70mph
Thursday, November 12th, 2009 AT 7:02 AM
  • 109,755 POSTS
Have you checked compression to that cylender? Also, are you getting power to the coil pack? Finally, if you have spark, have you checked the injector to see if it is pulsing?
Thursday, November 19th, 2009 AT 9:36 AM
