2005 Ford F150 Low battery message on stock headunit
37,000 MILES • V8 • 4WD • AUTOMATIC
FOXRACER7248
The other day i went out and started my 05 f150 stx and a message saying low battery poped up on my stock headunit my clock was erased it has done this three times now my radio is still fine but no one seems to know what is wrong. I took it to advance auto and had the battery and alternator tested and it all came back fine. Im confused on what it could be any help would be appreciated thankyou
Mar 9, 2008 at 1:03 PM
SERVICE WRITER
  • 9,123 POSTS
Sometimes things can be intermittant. In your case the battery may be weak enough to lose power. As it sets it rejuvenates enough to start. You start it, the alterater charges it, and it tests fine. Noramlly motorcraft batteries are good for a while, but unless you have a weak connection, I would be awful suspicious of the battery or the connections.
Mar 9, 2008 at 1:09 PM
