2005 Ford F150 Knocking noise
72,000 MILES • V8 • 2WD • AUTOMATIC
RICHARD.TORRES05
i have a 2005 ford f150 5.4 3v an it has a knocking noise when im around 1000rpms an i was told the cam phasers had to b replace so i had them replaced an the noise is still there.. what else can it be? and i also just changed out all my spark plugs
Jul 3, 2010 at 9:08 AM
  • 110,248 POSTS
Can you tell me aprox where the noise is coming from?
Jul 5, 2010 at 12:25 PM
RICHARD.TORRES05
It's coming from in the engine.. It knocks around 1000 rpms but when I go past 1200 rpms or so it goes away
Jul 5, 2010 at 3:50 PM
  • 110,248 POSTS
If it is coming from the engine, I would guess it is a crank or connecting rod bearing. However, usually they get louder when under a load.
Jul 5, 2010 at 4:45 PM
