2005 Ford F150 Injectors
PETE2
Engine Performance problem
2005 Ford F150 V8 Two Wheel Drive Automatic 164K miles
How do I tell if an injector is working. I have replaced all plugs. I am still getting a failure code on 5 & 7
Dec 23, 2008 at 8:03 AM
BLACKOP555
  • 10,386 POSTS
the only real way to see if its getting enough fuel from the injector is to use a exhaust gas analyzer and a spark kill hook up that way you can measure the amounts of raw fuel and compare with other ones to see if cylinders 5 and 7 are putting out too little, or no at all.
other tets include listen to the injectors with a probe. you should hear them clicking if they are working.
if not check for injector pulse at them with a noid light.
Dec 24, 2008 at 3:06 AM
