2005 Ford F150 injector failure
102,059 MILES • V8 • 4WD • AUTOMATIC
RONALDW
I recently replaced a 5.4 engine in a 2005 ford f-150 with a remaned unit. after install i am now getting injector failure codes on cyl. 2,3,4 and lean on bank 2. also getting code for cam pos sensor failure. could this have been caused by the engine failure.
Dec 11, 2008 at 10:06 AM
  • 110,248 POSTS
Hi:
If the cam sensor isn't working properly, the injectors may not fire correctly. Have the cam sensor checked.
Dec 12, 2008 at 7:18 AM
