2005 Ford F150 fuel pump/coil?
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICHAELCINDY
Hello-
My husband had his truck into the repair shop a few months ago because it was running rough intermittently and the engine light came on. They ran it on the diagnostic coming back with a misc code. Changed the fuel filter and decided it was the ignition coil, which they changed. The truck has been running beautifully. He just returned from a 2000 mile trip which it ran great. It is now back to running rough with the engine light coming on. When he describes it to me it sounds like a clogged fuel filter, but it was just changed. Should we change the fuel filter again and could it be the coil again? If it is the coil, what might be causing it to fail so soon. Thank you for your time- Cindy Wright
Jan 11, 2008 at 9:40 AM
BLACKOP555
  • 10,386 POSTS
get it scanned for trouble codes, i belive it may not even be related to the previous problems.
Jan 11, 2008 at 11:31 AM
