2005 Ford F150 FRONT END SHAKING WHILE BRAKING
38,000 MILES • V8 • 4WD • AUTOMATIC
DBREEN
My front end has been shaking while braking for a few months now. It is especially bad when braking with a camper hooked to the rear and also when I am coming to a stop on an uphill grade. I was told that it probably was warped rotors so I replaced the front rotors and pads. It seemed to help a little bit but it is still shaking when applying the brakes. I don't think it is the rear rotors because it really feels like it is in the front. What are the chances the new rotors are bad?
Oct 9, 2009 at 5:35 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your model is the Ford F150 but what is the engine size in liter
Oct 9, 2009 at 7:51 AM
  • 110,248 POSTS
Actually, the chance of the new rotors being bad is good. Most of the aftermarket parts are made overseas and are cheap for a reason. However, when you said it's worse going up hill, that makes me think there may be a problem with a ball joint or tie rod. Have you had the steering components checked?
Oct 9, 2009 at 7:52 AM
