2005 Ford F150 door locks
2005 FORD F-150
46,000 MILES • V8 • 4WD • AUTOMATIC
KEVINSOL
After the door locks are automatically locked by moving, the solenoid is activated, unlocking the doors.
Even when I relock them, they unlock and I can hear the solenoid clicking to continue to unlock the doors. This only happens when the truck is in gear.
It doesn't happen in Park with the engine running, or when I lock the doors with the engine off. This just started a week ago, I'm baffeled. This truck has a remote fob and keypad. What's going on, and how can I repair the problem?
May 1, 2009 at 3:52 AM
MERLIN2021
  • 17,250 POSTS
Pinpoint Test E: The Auto-lock Does Not Operate Correctly Normal Operation When autolock is enabled the vehicle security module reads inputs from: The ignition switch • The brake pedal position (BPP) switch • The door ajar switches (all doors closed) • The brake pedal position (BPP) switch and transmission range (TR) sensor inputs are received through the universal asynchronous receiver-transmitter (UART)-based protocol (UBP) communications network. Once the vehicle security module receives all 3 inputs the doors automatically lock. Possible Causes Circuit 344 (BK/YE) open • Circuit 345 (BK/PK) open • Circuit 346 (BK/WH) open (SuperCrew) • Circuit 363 (BK/LB) open (SuperCrew) • UART based protocol (UBP) communications network • Vehicle security module • Door ajar switches • PINPOINT TEST E: THE AUTO-LOCK DOES NOT OPERATE CORRECTLY E1 VERIFY THE AUTOLOCK FEATURE IS ENABLED Verify the autolock feature is enabled. • Is the autolock feature enabled? • Yes : GO to E2. ◦ No : TURN the feature ON with any configuration method. ◦ E2 CHECK ALL VEHICLE SECURITY MODULE DOOR AJAR PIDs FOR CORRECT READINGS Key in ON position. • Enter the following diagnostic mode on the diagnostic tool: Vehicle security module door ajar PIDs. • Monitor all vehicle security module door ajar PIDS while opening and closing all doors. • Do the PID values agree with the door positions? • Yes : GO to E6. ◦ No : GO to E3. ◦ E3 CHECK THE SUSPECT DOOR AJAR SWITCH CIRCUIT Key in OFF position. • Page 1 of 1 HANDLES, LOCKS, LATCHES AND ENTRY SYSTEMS -- F150 PICKUP -2005 Ford... 5/2/2009 http://www.ondemand5.com/mric/common/asp/printart.aspx
You may need to have it scanned for any fualt codes, this will pin point the problem part.
May 2, 2009 at 2:49 AM
