2005 Ford F150 Cold start engine sounds
22,000 MILES • V8 • 2WD • AUTOMATIC
GATROOPER
My F150 runs great but concerned about sound I hear at start up only when vehicle has not been run for 2 or more days. At cold start up, there is what almost sounds like a scraping noise for a second or two as the engine first fires. The sound goes away quickly and the oil pressure comes right up to normal range on the gauge. Is this normal for the 5.4 engines? It doesn't do this when truck is used daily.
Jan 16, 2008 at 10:55 PM
FLEXY5
  • 512 POSTS
Is this the new 5.4 3-valve engine?
Jan 17, 2008 at 1:51 PM
GATROOPER
Yeah, its the 3 valve 300 hp motor. It also idles a tad rough but has always done that. Runs smooth though.Is that common with these?[quote:05fc8d6be9="gatrooper"]Engine problem
2005 Ford F150 V8 Two Wheel Drive Automatic 22,000 miles
My F150 runs great but concerned about sound I hear at start up only when vehicle has not been run for 2 or more days. At cold start up, there is what almost sounds like a scraping noise for a second or two as the engine first fires. The sound goes away quickly and the oil pressure comes right up to normal range on the gauge. Is this normal for the 5.4 engines? It doesn't do this when truck is used daily.[/quote:05fc8d6be9]
Jan 18, 2008 at 9:46 PM
