2005 Ford F150 brake lights not working
125,000 MILES • V8 • 2WD • AUTOMATIC
PERKINSDADDY
brake lights not coming on,,signals are ok,, no blown fuses? ... truck was in accident, hit left frt. corner,, i had to replace the ABS unit?? i have bled it twice. but still have idiot lights on dash - ABS and brake..???
Can you help???
Jan 25, 2008 at 2:09 AM
  • 75,988 POSTS
Check the brake light switch -follow the brake pedal till it meets up with brake support the switch should be here-disconnect the connector and use a jumper wire-the brake light should come On. -Check-if so adjust it.
Jan 25, 2008 at 3:13 AM
