2005 Ford F150 blue smoke
104,000 MILES • V8 • 2WD • AUTOMATIC
WALTER EDWARDS
At idle my truck run rough as well as driving, i had a friend change 2 of the spark plugs after he used a hand held diano which told (from the codes) that 3 and 4 are not firing properly. 1)why does my truck fell as if it about to stall. 2) should all spark plugs be changed. 3) why do i smell burnt fuel when i get out of the truck
Mar 6, 2010 at 8:49 AM
  • 75,988 POSTS
2005 Ford F150 blue smoke means its burning oil-could be valves and rings, cylinder wear
Mar 6, 2010 at 8:51 PM
