2005 Ford F150 4x4 operation
86,500 MILES • V8 • 4WD • AUTOMATIC
WCARTER
I had the transmission repaired a year ago and had them inspect the transfer case area too and never checked to see if the 4x4 worked or not after the repairs. I locked it in 4x4 (switch on the dashboard) and I felt the front lock in or a "pull" so to speak but the wheels fail to turn to pull the truck up a slick dirt grade? Hasa a wire been left off or did they screw up my 4x4 to get another free warrenty bill payment?
HELP!!!!
Jan 24, 2009 at 11:11 AM
  • 110,248 POSTS
hi:
It sounds like the 4wd actuator isn't working. Check to see if there is power getting to the actuator motor on the side of the transfer case.
Jan 26, 2009 at 8:22 AM
