accelerator pedal position sensor?
2005 FORD F-150
87,000 MILES • V8 • 4WD • AUTOMATIC
ERBAS
My 2005 F150, 5.4L will enter a forced idle mode while I am driving. The vehicle displays three error codes, P2104 TAC - forced Idle Mode, P2111 TAC - stuck closed, P2111 TAC - stuck open. I have replaced the throttle body and Throttle Position Sensor. The Accelerator Pedal Position sensor seems to be working fine. I've also had the computer refashed after all this. Still same issues and codes. Any ideas? I'm thinking it might be in the computer.
Oct 11, 2010 at 5:41 AM
DOCFIXIT
  • 18,828 POSTS
Closed Open TP1 3.7-4.7V .3-1.9V TP2 .7-2V 4.1-4.7V Check V from TPS connector to ground TP1-pin 3 TP2-pin6
https://images.2carpros.com/forum/automotive_pictures/198357_Grafic_3_157.jpg
At PCM Connector E Tp1-pin E61 TP2-pin E60 voltage 5V reference If voltage not right at TPS check at PCM if correct then wiring if voltages correct then suspect PCM
Apr 21, 2021 at 4:33 AM
