2004 Ford F150 Won't shift out of park
2004 FORD F-150
50,000 MILES • V8 • 4WD • AUTOMATIC
BUD LEROY
2004 Ford F150 FX4 pickup. The truck starts and runs fine. Push on brake , brake lights work but the button on the shifter is not released to allow shifter to move from park. Fuses good, replaced brake switch
Aug 22, 2008 at 10:49 AM
BMRFIXIT
  • 19,053 POSTS
Check shifter interlock at the steering column
it has 4 wires
black should be ground at all times
red should be ground at all times
yellow should be battery power at all times
green should have power when brake light is on
good luck
Aug 22, 2008 at 11:10 PM
BUD LEROY
This truck has a console, are these wires there also? Where is the release solinold?
Aug 23, 2008 at 4:50 AM
BMRFIXIT
  • 19,053 POSTS
it on the side of the shifter
take console out and check
Aug 23, 2008 at 10:31 AM
