2004 Ford F150 replaced fuel pump
30,000 MILES • V8 • 4WD • AUTOMATIC
BEAUBRIT
Truck will not start ** new fuel pump will not turn on, but truck does run if I manually add power via a battery, to the pump the truck will run. The fuel pump will not self-engage***any ideas???
updated 3-1-09
Guys***I am sorry***but what is the PCM? and how do I check it? and the inertia switch? ***Have already checked all fuses***there is power at the fuse end of the fuel pump as well as power at the fuel pump itself, fuel pump will only engage when I hook directly to a battery!! *** where exactly is the fuel pump relay?
Feb 27, 2009 at 9:30 AM
BILLYMAC
  • 2,204 POSTS
check the inertia switch. unser right side kick panel.
check all fuses
check fuel pump relay
if all are fine pcm prob.
Feb 27, 2009 at 9:44 AM
  • 31,937 POSTS
Hi there, Check for power at the fuel pump relay (303) see pic, check power at relay as well.start here. mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_Graphic_106.jpg
Feb 27, 2009 at 9:47 AM
