2004 Ford F150 Rattle
100,000 MILES • V8 • 4WD • AUTOMATIC
R_MCALLISTER
My truck has developed a rattle that seems to be coming from beneath the truck in the middle of the front floor board. Rattle is not present until you accelerate. With car in park there is no rattle when you press the accelerator.
Any ideas would be greatly appreciated.
Sep 9, 2010 at 4:22 AM
WRENCHTECH
  • 20,760 POSTS
That is very likely a Catalytic Converter broken internally. If you crawl under the truck with the engine OFF. Use the heel of your hand to hit each converter sharply and see if one of them rattles.
Sep 9, 2010 at 4:42 AM
R_MCALLISTER
IS THIS A COSTLY REPAIR?
Sep 9, 2010 at 5:37 AM
WRENCHTECH
  • 20,760 POSTS
It can be. It depends on whether there is an aftermarket replacement available. Talk to an exhaust specialty shop and they can verify the problem and tell you what's available.
Sep 9, 2010 at 6:20 AM
