2004 Ford F150 oil pressure
128,000 MILES • V8 • 4WD • AUTOMATIC
RICK68
after warm oil pressure drops to L. shut it off and restart and its fine again for 5-10 mi. any ideas?
Jan 11, 2010 at 10:05 AM
  • 110,248 POSTS
WHen it drops, have you ever heard any ticking or knocking from the engine? If not, chances are you need to replace the oil sending unit. It's an easy job and the part should be under 20 dollars. If you need help, let me know. Also, if you do hear sounds from the engine, let me know. There could be internal problems.
Jan 11, 2010 at 2:46 PM
