2004 Ford F150 obd readiness?
2004 FORD F-150
62,000 MILES • V8 • 4WD • AUTOMATIC
GEERUSSO
I am trying to have my truck inspected, but my catalyst and 02 components have not moved to ready and are still incomplete. I have driven through the proper drive cycle laid out by ford more than once and still nothing. I have given at least three cold soaks as well. I am not pulling any codes, is it a question of just time or could their be a malfunction with the cat or and o2 sensor that is not allowing the obd to finish. Wouldn't that pull code though?
Jul 26, 2010 at 3:07 AM
  • 110,244 POSTS
The cat and O2 sensor have nothing to do with the reset. I would swap out the thermostat because it sounds like it is stuck open not allowing the engine to get up to temperature. That should fix it.
Jul 26, 2010 at 3:14 PM
BIGMIKAL2006
I am having same issue and installed a new thermostat, it was broken. monitors reset.
Sep 17, 2012 at 3:01 PM
