My drivers rear brake or wheel makes a "mooing" sound as you let up off the brake pedal what could this be?
Sep 12, 2009 at 4:40 AM
✓Experienced Mechanic
Have you checked to make sure the brake springs are not broken or there isn't something out of place that can be causing a rubbing?
Sep 16, 2009 at 1:05 AM
DMAN351974
MEMBER
Yes I have pulled off both rear tires and taken the calipers, pads and rotors and inspected everything and cleaned and adjusted everything also. Still "mooing" or moaning.
Sep 18, 2009 at 3:31 AM
If the noise is from the rear, then it must be in the differential or an axle bearing. Check for problems there.
Sep 18, 2009 at 3:45 AM
DMAN351974
MEMBER
It isn't the rear diff I know that. It is in the rear brakes. I am just not sure whether it is a "sticking" caliper, pads, rotors, e brake or what.
Sep 18, 2009 at 4:36 AM
If you checked it, I don't know what to say. My first guess would be the poorly designed park brake.
Sep 18, 2009 at 6:28 AM
DMAN351974
MEMBER
[quote:1ffb0cac59="Jacobandnickolas"]If you checked it, I don't know what to say. My first guess would be the poorly designed park brake.[/quote:1ffb0cac59]
Actually the parking brake is fine. I believe it has to do with the caliper on the rear drivers side.
Sep 22, 2009 at 4:36 AM
Is it sticking at all?
Sep 22, 2009 at 6:28 AM
DMAN351974
MEMBER
I don't know for sure that it is sticking but everything else is good. I am pretty sure it is the caliper.
Sep 24, 2009 at 10:14 AM
