2004 Ford F150 making a clicking noise at the front passeng
86,320 MILES • V8 • 4WD • AUTOMATIC
JOLVST
  • 6 POSTS
the clicking noise only start up when i start drivng and the faster i go the louder the noise get, but i can put it in 4WD the noise stop. CAN SOMEONE PLEASE HELP ME.
Sep 17, 2010 at 1:11 PM
MADMIKE1735
  • 951 POSTS
not sure i understand. it clicks when you start the vehicle, or when you start driving???? if you put it in 4x4 while driving and it stops, i would check your front driveshaft u-joints.... also check your front cv axles.... again, these are things that will cause a slight noise at low speed, and get louder with speed, and also disappear with 4x4 engaged.... let us know
Sep 17, 2010 at 1:18 PM
JOLVST
  • 6 POSTS
i will check the u joint&cv joint and i'll let u know how it goes. madmike i thank you very much.
Sep 17, 2010 at 1:50 PM
MADMIKE1735
  • 951 POSTS
your welcome, thats what were here for....
Sep 17, 2010 at 1:57 PM
JOLVST
  • 6 POSTS
it was the cv joint. i change the cv joint the noise stopped thank you very much madmike.
Sep 21, 2010 at 2:41 PM
MADMIKE1735
  • 951 POSTS
no problem... glad everything worked out for you.
Sep 22, 2010 at 2:43 AM
