2004 Ford F150 maf sensor
2004 FORD F-150
107,000 MILES • V8 • 4WD • AUTOMATIC
FRCATON
my truck started running bad when I ran it low on gas and the check engine light came on. I assumed it was trash so I changed the fuel filter, put some gas treatment in the tank and filled 'er up. No help. a local parts store put a code reader thing on it and it mentioned two codes which i don't remember. But they were both relateted to the O2 sensor. The guy said it was most likely the MAF sensor. I cleaned it with electronic parts cleaner and it ran fine for awhile and then it started acting up again. I replaced it with a reconditioned MAF unit and it is still doing the same thing. Now what?
Jul 1, 2010 at 11:09 PM
  • CAR REPAIR CONTRIBUTOR
Hi frcaton, Welcome to 2carpros and TY for the donation
We gonna deal with this step by step-check the fuel pressure with a gauge and comeback with the readings we start here.
Jul 2, 2010 at 3:33 AM
