2004 Ford F150 gas pedal is not releasing fuel to the engin
2004 FORD F-150
191,000 MILES • V8 • 2WD • AUTOMATIC
ZILHAD
My truck was running fine. Yesterday batery died. I disconnected and replaced with new batery from NAPA. Started truck fine. When I tried to push gas pedal fuel did not go to the fuel injector. So I do not know what it could be? Is it electrical or mechanical?
Please help.
Thank you
Mar 19, 2010 at 12:01 PM
  • 110,244 POSTS
When you hit the gas. you are opening the throttle plate. A sensor determines how much fuel the injectors get. Therefore, I need you to check to make sure the fuel pressure is good. Here is a how to for checking:
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find. Also, let me know if the check engine light is on.
Mar 20, 2010 at 5:03 PM
