2004 Ford F150 fuel injectors
CORA11
Engine Performance problem
2004 Ford F150 V8 Four Wheel Drive Automatic
how do you know when an injector is going bad
Apr 18, 2009 at 12:02 PM
JAMES W.
  • 2,394 POSTS
Usually, if you locate a missing cylinder(s) and the spark and compression are good, it's usually the injector(s). The only surefire way is to change a suspected injector, or have it tested.
Apr 18, 2009 at 3:18 PM
