2004 Ford F150 Fog Light Maintenance and Repair
2004 FORD F-150
62,000 MILES • V8 • 4WD • AUTOMATIC
JOLLYROGER_57
I drove through a large puddle and broke both fog light bulbs. I replaced the bulbs and they worked until it rained again although, I don't remember going through any large puddles. Now they do not work. The bulbs cost $20 or so each and I do not want to replace them after every rain. I noticed also that the fog lights are cloudy and there is broken glass from the bulbs inside the lens. Is there something else I should do - like caulking or taping or otherwise sealing the bulb component - besides replace the bulbs? How do I kep moisture out of the fog light assembly?
Sep 17, 2009 at 9:00 AM
  • 110,244 POSTS
If the lens is cracked, it needs replaced. Also, there should be a gasket between the lens and the assembly to keep water out.
Sep 17, 2009 at 2:21 PM
