2004 Ford F150 engine smells like gas inside cab
70,000 MILES • V8 • 4WD • AUTOMATIC
THOMASSCHROEDER
engine has mis and smells like gas in cab.
we changed fuel injectors it is still the same do you know what it could be?
Feb 21, 2008 at 11:20 AM
MERLIN2021
  • 17,250 POSTS
Have you had the codes read yet? Autozone tests for free, get the printout, and post the codes here...also if fuel related, Autozone can rent you a fuel pressure tester, read the pressure, then remove the vacuum hose to the pressure regulator, apply a bit of vacuum to the regulator, any change in engine speed? Pressure? Now pinch the fuel return line, any increase in pressure? If not change the regulator.
Your purge cannister may be full of gas...if any gas is in it, replace it and repair the pressure problems and return line.
Feb 22, 2008 at 12:35 AM
