WHAT YOU ARE SEEING PROBABLY LOOKS LIKE "WHITISH" OR "YELLOWISH"!
COMBUSTION PRODUCES ALL KINDS OF GASSES, TO INCLUDE WATER VAPOR
"BLOW-BY" IS WHERE SOME OF THIS STUFF SORTA "GETS PAST" THE PISTON RINGS AND "SEEPS" INTO YOUR CRANKCASE (IF WE LIVED IN A PERFECT WORLD, THIS WOULD NEVER BE ALLOWED TO HAPPEN!)
BUT IT DOES, NEW OR OLD ENGINE, THE MORE WEAR, MAYBE THE WORSE BLOW-BY IS
YOUR POSITIVE CRANKCASE VENTILATION (PCV) REMOVES THE GASSES, THEN SORTA RE-BURNS THEM, AS SOME OF THESE GASES ARE CORROSIVE (THE WHOLE REASON, THE PCV IS THERE, IS TO REMOVE THEM)
INSURE THE PVC SYSTEM IS STILL CONNECTED CORRECTLY, MAKE SURE THE PCV VALVE OPERATES (IT'S SORTA A TUNE-UP EXPENDABLE ITEM, THAT MAY BE OVERDUE ON REPLACEMENT)
THE SOURCE FROM WHICH THE VACUUM COMES FROM, COULD BE PARTIALLY BLOCKED, AS IT ENTERS TE MANIFOLD. ON MY JEEP, THIS WAS THE CASE A LONG TIME AGO, I HAD GOOD VACUUM ON A GAUGE---JUST NOT ENOUGH FLOW. THERE WAS GRAYISH/ SILVERY BUILD-UP IN THE "N.IPPLE" AT MY INTAKE MANIFOLD. AFTER CRUNCHING IT OUT, I HAD TO READJUST THE CARB. IT WAS GETTING CORRECT AIRFLOW NOW, IT HAD BE ADJUSTED EARLIER WITH THE WRONG FLOW OF AIR. THE "SNOT" SOON DISAPPEARED FROM MINE.
CAN YOU HANDLE IT, OR DO YOU MAYBE NEED DIAGRAMS OR SUCH?
THE MEDIC
Jun 18, 2020 at 6:09 AM
(Merged)
