2004 Ford F150 codes---P2106 with C1230
78,000 MILES • V8 • 2WD • AUTOMATIC
WGHEINTSCHEL
I have the wrench light and ABS light on dash with codes P2106 and C1230? Can I repair this?
Feb 12, 2010 at 2:05 PM
RACEFAN966
  • 5,029 POSTS
Ok P2106 has to do with the EGR system module to do more diagnostics on this you will need a scan tool and maybe a digital multi meter.
C1230 is the commonly the rear speed sensor on the top of the differential or one of the front speed sensors. With a digital multi meter this can be tested to see which it is. Let me know what you want to do. I will walk you through the tests.
Feb 13, 2010 at 1:10 AM
