2004 Ford F150 Clutch Master Cylinder or Slave?
200,000 MILES • 6 CYL • 2WD • MANUAL
HOSSOLA
Hello. My truck is a 2004 Heritage edition (old body style) F150. It has the 4.2L V6. The clutch does not slip, occasionally it will grind and is always hard to shift into first gear. I suspect that it is the master cylinder. What do you think?
If it is the CMC, could a motivated guy replace it himself, or is it internally mounted in the Trans?
thanks much,
Rob
Sep 13, 2010 at 4:46 AM
  • 110,248 POSTS
Does the trans shift smoothly when the engine is off?
Sep 14, 2010 at 12:17 AM
