2004 Ford F150 Clutch
53,000 MILES • 6 CYL • 4WD • MANUAL
WIN348
04 F150 Heritage 4X4, 4.2 V-6, 5 sp manual. Have recently had to begin adding fluid to clutch reservoir and noticed clutch chatter until vehicle is driven/warmed up. When level gets low, have excessive free play in clutch. Suspect slave cylinder is leaking as this seems common problem with this vehicle. Slave cyl is internal to bell housing and therefore must drop trans etc to repair. Question: are there any after market kits to convert this hydraulic clutch to mechanical linkage? Or, if I repair it, is there a fix to the existing slave to ensure it lasts longer than 53K miles before leaking. Finally, since the leaking fluid must be getting on the clutch disk to cause the chatter, should I go ahead and replace the entire clutch when it is apart? Thanks
Dec 27, 2007 at 11:41 PM
  • 31,937 POSTS
Hi there,
You will not be able to convert clutch to mechanical linkage, when box is out to replace slave, inspect clutch and replace if required also machine the flywheel as this is a common cause for chatter.
mark (mhpautos)
Dec 28, 2007 at 9:12 PM
